Touch screen will not work
After the tablet was dropped the touch aspect of the screen will not work. The tablet will power on and screen is normal and via able but I can't do anything.
この質問は役に立ちましたか?
Hi,
The digitizer (touchscreen) has probably gone faulty and it will need to be replaced.
Here is a link that shows how to replace the LCD screen and the Digitizer. They are glued together and although they are able to be separated, without the equipment necessary to do this it is better just to replace them both, as it will probably be easier to do as well as cause less damage.
https://www.youtube.com/watch?v=t2O5Dt1I...
Here is a link to just one supplier of the parts. It is not a recommendation to use them. It is merely to show what options are available. If in doubt about which part is the one you need, contact the supplier for further information
http://www.etradesupply.com/catalogsearc...
Hopefully this is of some help.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 7
今までの合計 807
