メインコンテンツにスキップ
The HP Chromebook 14 is a variant of the Google Chromebook line released September 11, 2013. Model number is 14-Q010DX.
10回答 すべてを表示
Why is my screen blank?
I had some Chrome OS defective notices pop up all of a sudden. It required me to use the Chrome OS recovery utility to create a USB Recovery drive to re-install the OS. It worked, and things went back to normal...for a little while. Then the Chrome OS defective issue popped up and got fixed several more times, until finally...the screen would stay blank when the Chromebook was powered on. I could still hear the fan running, and see all the usual lights, like power on indicator light, etc.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
ベストアンサー
Ultimately, purchasing a new 16GB SSD for $17 on ebay solved the problem and now the machine is running perfectly!
I didn't use the exact same brand that was in there, because this other one was the cheapest. Here's the title of the ebay posting I purchased the part from:
16GB SSD Hard Drive LSS-16L6G-HP 735314-001 HP 14-Q010NR Genuine (A01)
In the computer the part is mounted on the motherboard and underneath the motherboard, as you'll see when following one of the already available guides.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
good.:) from'love heaven' thats my name
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Stephen Jennings さん、ありがとうございました!
統計データ:
過去 24時間: 3
過去 7 日: 3
過去 30 日: 9
今までの合計 1,215
