メインコンテンツにスキップ
Nabi 2S is a tablet created just for kids. It is powered by a NVIDIA® Tegra® 3 Super 4-Plus-1TM Quad-Core with 5th Battery Saver Core; it has 16GB storage, a 7-inch, high-resolution (1280 X 800) touch screen, and a front facing camera.
9回答 すべてを表示
Why is my tablet not charging?
I plug my tablet in and it doesn't charge at all, why is that happening and how do I fix it?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 3
コメントを追加
2件の回答
最も参考になった回答
The Nabi tablets I have fixed for charging are the charging port on the tablet. The solder joints have most likely come free of the circuit board and need to be replaced. You will want to check the charger for proper output voltage before opening the tablet and checking the charging port.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
Do you know where I could find a charging port for the Nabi 2S?
さんによる
The charging port for the tablet will be a round hole on the tablet and will have a metal post that protrudes from the center of that hole.
さんによる
コメントを追加
If your having trouble charging your tablet, there might be a problem with the charger itself. If you have tried a new charger and the problems persist, I would suggest replacing the battery on the tablet. Please refer to our troubleshooting page for more help!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Molly Scott さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 5
過去 30 日: 5
今までの合計 780
