メインコンテンツにスキップ
iPhoneの5代目となるiPhone 4S。このデバイスの修理は比較的簡単で、スクリュードライバー、開口ツールと忍耐が必要です。GSM/CDMA / 16, 32, 64 GB / 白と黒
2193回答 すべてを表示
締切られた回答
Dark spot after replacing screen?
So i replaced the screen on my 4S (first repair on an iPhone i have done) and its gone okay, everything works just i couldn't quite get the front and back to fit snug and it took some effort to get the back on. The new screen works perfectly fine just there's a small dark spot in the middle right area of the display and i was wondering what might have caused it? (it doesn't really bother me the previous owner had badly scratched the original glass anyway so its still a vast improvement)
there were small gap when a fitted the new screen and it was a cheap £10 screen from ebay so it might just be like that or have a damaged it when fitting?
thanks in advance for your help :)
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
Hi Sam
Sometimes you can get faulty screens when you buy from eBay, so maybe not your fault maybe just the screen.
Have a good day
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
sorted it out it turned out to be a shield that had come loose in the back part of the phone must've been putting pressure onto the display somehow.
さんによる
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 3
過去 30 日: 3
今までの合計 417
