Microphone could be damaged?
In my new Samsung Galaxy s7 edge I put by mistake the pin for the hole of the storage of the SIM card instead of there to the hole of the microphone who is near .
Do you believe I have damaged the microphone ? How can I realize it ?
Update (05/01/2016)
Anybody could commend about the waterproof situation after that action mentioned above ?
この質問は役に立ちましたか?
8 件のコメント
Any help to be informed about possible damage and also water protection ?
Costa さんによる 共有
It is very possible to have damage the mic. However, if you were gentle then you may not have. A quick test for your mic would be a phone call or voice commands(if no one can hear you then its broken, or if the commands dont work). If everything seems clear then no worries, if not then it is safe to assume damage was done.
Henry さんによる 共有
السلام عليكم انا عندي مشكلة في جالكسي اس 7 ايدج الجهاز مقاوم للماء وهذا معروف لكن انا وضعته في الماء ثم لم يعد يشتغل ابدا اتمنى الرد
mo3jzh 1 さんによる 共有
Which mic do you mean guys? Galaxy S7 has two mics: on the top, and on the bottom...What if the try opening tool is inserted into the mic located on the phone's bottom? Can this damage the bottom mic and/or damage the water seal?
Alta ir さんによる 共有
According to a post made by user Jimmy, the galaxy S7 mics and water resistant mesh is parallel to the hole, such that inserting a pin will go next to that Mic but not penetrate it if straight down.
Not answered is if there's anything under it that the pin will come in contact with.
F V さんによる 共有
3件以上のコメントを表示
