メインコンテンツにスキップ
カウンタートップとハンディブレンダーの修理ガイドをまとめたものです。
346回答 すべてを表示
stripped gear connected from the base of the blender to the pitcher
My Ninja blender 10100 watt model BL700 30 will not blend when I have something in it but will spin when it is empty it will not even blend ice cream I believe it is stripped in the base gear or whatever you call the gear looking thing in the bass that connects to the picher.. apart to get it off an epoxy it or something but I can't figure out how to get it off
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
Do not dispair. The stripped gears can be repaired by replacing the 3 small gears and just a small amount of enginuity. https://sites.google.com/site/dgeake51/h...
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
How i can find thes pices tank you
さんによる
Go to this site: https://sites.google.com/site/dgeake51/h.... Step by step instructions.
さんによる
コメントを追加
Your blender has stripped planetary gears.
It's shot. Toast. Too hard to fix.
Why? 1. No easy parts suppliers. 2. Hard to disassemble when the gears are stripped because you can't separate the motor from the gears.
Ninja put in cheap (non-metal) plastic planetary gears in these units. They work ok for most things, but not for ice crushing drinks. While they put the motor mounts on rubber supports, and the drive connection to the base of the blender is rubber, these do not protect the gears from easily being overloaded with the large multi blade pitcher when it is full of cold (hard) ice.
They need to warn people who buy this for ice blended drinks to fill the blender only half full of ice. It's not strong enough to handle a lot of full-pitcher ice drinks.
Mine broke on the fifth pitcher.
They know about this problem, as you only need to search for it in Google. But why is it not fixed? Why is there no recall? Why does Costco carry it in view of their QC policy?
I don't know, but someone should sure get going on this problem I think.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
the plastic gear is cheap, bad design, they should have never made the gear out of plastic. throw it away and buy a new one
さんによる
Where do you find the gears? I need to replace the planetary gear, but can't seem to find those kind of parts online.
さんによる
コメントを追加
回答を追加する
allenmc503 さん、ありがとうございました!
統計データ:
過去 24時間: 4
過去 7 日: 20
過去 30 日: 65
今までの合計 7,299
