メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
iPhone is searching for network
My iphone 5 today suddenly started started searching network,
I took out the SIM card , it still kept searching for network instead of saying no sim or no service.
I reset network settings, then all settings, turned phone on off several times, put back sim in, hard reset it etc.
I haven't restored it from itunes that I will do next but I am wondering if any one had simlar problem.
Taking SIM card out should changed it to no sim or no service but it doesn't do that so that is weird.
Another thing is it doesn't give me an option to select carrier manually as that option has disappeared from the settings.
Please help
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
2 件のコメント:
Do you still have an IMEI number displayed in the Settings > General > About Phone? (Don't post the IMEI number here as it uniquely identifies your phone)
さんによる
whaaaat the !&&*, I cant find it O_o
さんによる
コメントを追加
2件の回答
This can happen if the time/date is set wrong. Try manually setting the time, pop the SIM card in. If that connects to network change the time setting back to Auto.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
The date is correct:/
さんによる
コメントを追加
There are too ways to solve it.
Method 1(you already tried):
Try Reseting Network Settings by going into
Settings>General>Reset>Reset Network Settings
Your phone will restart deleting wifi passwords and so on.
Method 2:
If it's a hardware problem then the only solution is to heat the baseband ic (under sim tray) with a hairdryer for approximetely 5 mins
According to iPhone could not be restored unknown error 1
Do not try to Restore phone via itunes cause your phone will be unusable (happened to me)
Post back with the results
このアンサーは役に立ちましたか?
スコア 0
3 件のコメント:
So what will happened if I would heat it? He did not get wet :/
さんによる
well, nothing happend
さんによる
You can find your IMEI on the settings? If you can't then it's hardware problem
さんによる
コメントを追加
回答を追加する
David Jan さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 3
過去 30 日: 3
今までの合計 244
