メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Nintendo GameCubeは、任天堂の4番目の家庭用ゲームコンソールです。修理は簡単で、一般的なツールだけで行えます。
Screen colour black and white while playing
The screen is black and white when playing
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 4
1件のコメント
Black and white screen when playing games ...The Smart T.V is to Smart for this Technology or does not know how to Advance with this Technology...
U.F.O Technology 😂
さんによる
コメントを追加
4件の回答
ベストアンサー
Hi Allposition,
A GameCube can display black and white when the video cables aren't hooked up correctly. Most GameCube cable harnesses have composite cables, component cables, or some combination of the two. If you inadvertantly mix up these connections, the video will display incorrectly. I'd check the back of your TV to make sure your system is wired up correctly. If your setup is correct, you might actually have a faulty cable harness. You can buy replacement cables here.
このアンサーは役に立ちましたか?
スコア 1
2 件のコメント:
I have composite but I have eight holes the components can be plugged into which holes would they go in
さんによる
コメントを追加
最も参考になった回答
check to see if your tv is in av mode, often this mistake is your in component mode which requires 5 things, av is the mode you want it has the 3 things, sorry dont know what they are called
このアンサーは役に立ちましたか?
スコア 7
5 件のコメント:
Thank you! This was my issue!
さんによる
I've searched for hours for a fix and this was it the whole time you deserve a medal
さんによる
i dont have the av setting and also i only have three things to insert. i dont even have and place to put the other 2
さんによる
how do i get it in av mode
さんによる
Saved my bacon
さんによる
コメントを追加
I have a 4k smart TV and am trying to use the 3 colours in the back. There is no yellow just yellow and green. But it's coming up black? Is the TV to high pixels to be able to take this is to I need to get another cable?
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
I have yellow and green as well. Better buy and older TV. lol
さんによる
コメントを追加
Have replaced all cables and still showing black and white… is it possible my tv is too advanced or can this be due to the console itself?
このアンサーは役に立ちましたか?
スコア 0
2 件のコメント:
Your comment had me DYINGGGG LMFAOOOO ?????
|is it possible my tv is too advanced|
SENT ME
さんによる
Well, I have just fixed my Nintendo Game cube to my LG Smart TV and there is no colour! How smart is that?
さんによる
コメントを追加
回答を追加する
allposition さん、ありがとうございました!
統計データ:
過去 24時間: 5
過去 7 日: 24
過去 30 日: 114
今までの合計 76,780
