メインコンテンツにスキップ
The Mazda Capella was commonly known in markets outside Japan as the Mazda 626. The Mazda 626's sixth-generation was built on the GF platform and released in 1997 for the 1998 model year.
52回答 すべてを表示
ambient air temperature semsor
where is this located
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
2件の回答
選択されたソリューション
There are two possible air sensors on your car . One to tell the outside air temp for you cars thermometer on your overhead council or on the dash depending on the model . This is located in front of the radiator in the front of the car just behind the grill opening . The other is the air temp sensor for the fuel mix and it is located on the breather box . It is on the side of the air filter box next to the fuses box. Don't confuse it with the mass airflow sensor which is in air duct between the air box and the throttle body. Hope this helps
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
Hi,
In a lot of vehicles it is mounted on a clip, located behind the front bumper, in front of the radiator. They are usually cylindrical in shape, about roughly half the length of a AA battery.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Hi OT03,
Thanks for adding the pic
さんによる
You are welcome, makes your great answer a bit more visible.
さんによる
コメントを追加
回答を追加する
stuarthughes1520 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 478
