メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
Huawei P8 Lite(モデル番号ALE−L21)は2015年4月にシンプルな美しさをテーマに発表されました。プロ級のカメラは、暗所でも自然やシャープな画像を撮影できます。
Why motion control page does not open?
When I want to go the setting>motion control, this page doesn't open and I only see a white page. I think this error is due to the model No. and build No.;
Model No.: hi6210sft
Build No.: BalongV100R001C50B311
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
1 件の回答
ベストアンサー
Hi,
Try the following:
1. Make a backup of your phone using the phone's backup feature.
2. Perform a factory reset on your phone.
3. Once completed, check to see if the motion control page is now available.
If not, then perhaps you are right.
4. If it is available, restore your phone using the phone's restore feature.
5. Once phone is restored, check to see if motion control page is available.
If it is, perhaps there was something wrong with the OS that has now been reset.
If it doesn't work again, perhaps there is a downloaded app that is causing the problem. Finding out which one will be the hard part.
このアンサーは役に立ちましたか?
スコア 3
4 件のコメント:
Really, the motion control feature does not work from the day I bought it and I only see a white screen. Also I try factory reset, but it does not work.
さんによる
Hi,
OK if that is the case, check the warranty period of the phone and if still valid, consult the warranty section of the User Guide as to what you have to do to make a warranty claim for repair or replacement. If you can't find the User Guide , go online to the manufacturer's website and search for 'warranty.
さんによる
Thanks for your answering. I ask some technicians about this problem; they said that these model number and build number are not complete and correct.On the other hand, the firmware of the phone must begin with 3 letter such as ALE. So I think that I must a method to flash my phone to the correct package. But I don't know enough how to do this.
さんによる
Hi,
Found this, hopefully it may be helpful to you. http://huaweifirmware.com/huawei-p8-lite
さんによる
コメントを追加
回答を追加する
Masoud Kamyab さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 6
過去 30 日: 20
今までの合計 1,373
