Why is the jigsaw not cutting straight?
When I am using my jigsaw it is not cutting straight. I have the angle set at zero but it is still not cutting straight. What should I do?
この質問は役に立ちましたか?
この質問は役に立ちましたか?
First of all you would need to check the materials on which the jigsaw is cutting. There's a circular knob that have different materials and it's photo of it. Second, sometimes the Jigsaw inserted incorrectly. Check the front of the base of the jigsaw and you'll see a black lever. Lift it in order to insert the blade and make sure to insert the blade with the sharp side facing outwards.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 2,043
