メインコンテンツにスキップ
The Palm Zire m150 is a handheld, touchscreen PDA. It was manufactured by Palm in 2002. The the PDA has a 2 MB RAM and 2 MB installed memory.
1回答 すべてを表示
締切られた回答
How do I delete files from the Palm Zire M150?
How do I delete files from my Palm Zire m150 I installed adobe reader and I installed too many books and my memory is full so I can't open adobe. I used adobe's tool to install them and I can't seem to find any way to uninstall them.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
When you turn on your palm there should be a bar at the top that has the time in it. Tap that with your stylus. There will be a drop down menu and tap "delete". From there your palm will generate a list of all the programs you have installed. After the list is done generating tap the program you want to delete and then tap the delete button. It will delete the program and you will not have it on your palm. Hope this helps. If you need further help please leave a comment.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 92
