メインコンテンツにスキップ
モデル番号はA1238/80、120、160GBハードドライブ/ブラックもしくはシルバーメタルフロント
904回答 すべてを表示
締切られた回答
Proper Part for iPod MC297LL?
My iPod classic 160GB earphone jack got bent to the point that audio only came out on one earphone. I gave it to a electronics repair shop and they replaced the audio jack cable but could not get audio to work and now it sounds like static and when you pressure the jack to the left the audio improves greatly. I was wondering if since I got model number MC297LL they got the thin or thick audio jack confused and installed the wrong one. I also was wondering if the right parts can be got since they appeared to be out last time I checked here. If I could get the right part for 15 dollars I might try to get it back up because it would save me hundreds of dollars.
-Thanks
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
ベストアンサー
@kwjameblond this "when you pressure the jack to the left the audio improves greatly." would not be an issue if the "thick" or "thin" got messed up. It sounds like a bad audio jack. Replace it once more with a part from here
このアンサーは役に立ちましたか?
スコア 3
2 件のコメント:
Thanks for the response, now how would I know if it was thin or thick?
さんによる
There is really is no good way that I know of. You could use a kitchen scale and weigh your iPod The "thick" is ~5.7ounce's/163g and the "thin" is ~4.9 ounce's/137g. Check your serial number on this site and see what it tells you.
さんによる
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 1
今までの合計 204
