メインコンテンツにスキップ
Repair guides and support for your Sanyo TV.
360回答 すべてを表示
締切られた回答
Why will my Sanyo LCD led tv not light up?
I have a sanyo 32" LCD LED TV model #dp32d53. The other day I turned it on and it turned on fine showing a gray screen with the channel number but then all of a sudden the screen went black. It still has sound and the screen still works I did the flash light test. The TV has the main board/ power supply/ backlight inverter all on one board. From what I found out online if the screen still works but its not lighting up its probably the led driver/backlight inverter so I ordered a used board from a web site that said it came out of the same model TV with a broken screen. I just got the part in the mail today and changed the boards out but it is still not lighting up. If anyone could please help me I would be very greatful. Could it be the actual LEDs? If so is it a costly fix?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント:
@mjkbuddha87 unlikely that all the LED's would have failed. Post some images of your boards and wires with your question. For that use this guide iFixitでの質問に画像を追加する方法
さんによる
コメントを追加
1 件の回答
It sounds like you are still having an issue with the backlighting. If the LEDs were bad, you would have no picture (fail flashlight test), I would think. Could be a fuse or connection issue in the backlight cicuit. Try searching for a schematic and test the circuit.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 3,057
