メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
This laptop was released in September of 2010, Identified by model number Inspiron N5030 or Inspiron 15. It is an all black laptop with a DELL logo in the center of the top cover, a mouse pad with separated left and right key buttons, and a disc drive on the right hand side of the computer.
No sound when I plug in my earphones
My Dell N5030 has no sound when I plug in my earphones. The speakers work fine, they shut off when I plug in my earphones , just no sound in the earphones. I am running Windows 10. I have looked for device manager can't find it.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 11
1件のコメント
Thank you for your response. This computer was a Walmart demo and had a ton of crap in it, and came with no paperwork. It had Windows 7 on it, I loaded Windows 10 when it came available. For the most part like it, but it does have it's quirks. I do believe that the problem is hardware related.
さんによる
コメントを追加
6件の回答
ベストアンサー
Do the headphones work in other devices? There may be a problem with the headphone port itself. Try other headphones or auxiliary cords. Since the speakers turn off when you plug in, there is most likely a problem with the hardware.
このアンサーは役に立ちましたか?
スコア 7
1件のコメント:
I have new earphones, I believe the problem is in the hardware. This computer was a Walmart demo and there is no end to the crap that I have had to dig out of it. I do thank you for your reply.
さんによる
コメントを追加
Hi,
Try pressing Win Key and x key on the keyboard together. You should see Device Manager link listed among other links on left hand side. Alternatively select the Control Panel link (same two key press) and then select the Device Manager icon.
Dell does not support your laptop for Win 10, so there are no drivers for it. However here is a link that has Win 10 drivers for your laptop, (their drivers have worked for people I know - not your model but still worked). Scroll down to find the Audio drivers, install them and see if that solves it for you, in case it was a hardware/software incompatibility problem. If it doesn't you can always revert back to what you had.
http://www.driverscape.com/manufacturers...
このアンサーは役に立ちましたか?
スコア 5
1件のコメント:
How do I revert back to what I had? I installed those audio driver things and it didn't work, and I'm worried I messed something up.
さんによる
コメントを追加
Have you tried plunging in your earphones into another device like an iPod, mp3 player, or stereo system to see if they work? If they don't work then the problem is with your earphones and not your computer. Also I would try to connect a different set of earphones or speakers to the earphone jack on the computer to test the jack out to see if it works. If there is no sound then the problem would most likely be with your computers earphone jack.
To get to Device Manager in Windows 10 to check the sound drivers, right click the Start button and click on Device Manager. Double click on sound, video and game controllers, right click on each device and click properties and make sure all the drivers are working properly.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
Try hard booting it. I know it’s not the best thing for the computer but it worked for me.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
I have a same problem with my dell inspiron. its because the Driver update all by itself and does not support your device.Follow the step Below to solve this problem..
This PC>Properties>Device Manager>Sound and audio Driver >Roll Back Driver
Hope this Work with Your Device.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
What worked for me is by going to Device Manager, then under Sound, video and game controllers, select Intel(R) Display Audio and disable device. Once I did that the sound came through immediately.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
David Blakeman さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 15
今までの合計 71,744
