メインコンテンツにスキップ
2012年9月12日に発表されたApple社による6番目となる iPhone。このデバイスの修理方法は前モデルと類似しており、スクリュードライバーと開封工具が必要です。GSMかCDMA方式、16/32/64 GB。 本体色は黒と白。
2522回答 すべてを表示
Repaired water damaged iPhone is having some problems
i dont know if anyone can help me on here.
iphone 5s water damaged.. i cleaned it properly. it worked but::
1 sucks alot of power (battery draining fast)
2 every 5 seconds of use it gives a warning. " temperature too hot cool down before use"
.. i can touch the motherboard and feel that its on normal temperature not hott..
solutions as per my experience:
battery draining fixed by replacing u2 ic.
any solutions for temperature too hot warning, any ideas where to look on motherboard for this..
thanx in advance..
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 0
1件のコメント
Hi remove all the metal brackets, switch the phone on and try to find where the heat is coming from. There should be component that is overheating. If you find it you have to replace it and then phone should work fine.
さんによる
コメントを追加
1 件の回答
ベストアンサー
First don't repair liquid damaged phones if you can. They're a nightmare and keep coming back for various issues.
Second, try a new battery. A known good battery of great quality or at least different source from the one you have in there if you already replaced it.
If that doesn't fix it, and you still experience fast battery depletion, heat, and still see this message, then you have a short somewhere. This short may be producing heat and activating this temp warning message.
If you see the message without heat, then one of the heat sensing resistors on the board was damaged from the liquid spill.
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
brisbane wholesalers さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 78
