メインコンテンツにスキップ
AmazonのBluetoothスマートスピーカー。2014年11月6日に発表されました。AmazonEcho SK705DIは、音楽再生、ニュースの閲覧、リストの作成、質問への回答など、さまざまなタスクを管理できる音声起動のクラウドベースのアシスタントを備えています。
The remote control does not pair with the with my device.
I tried to pair the remote control with the device and for some reason I can't get it to work or pair with the device. How can I pair the remote to the device?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 9
1件のコメント
My Echo remote keeps unpairing After I Successfully Pair it.
Why???
さんによる
コメントを追加
4件の回答
最も参考になった回答
If standard pairing process for remote does not work, it could be the software on the remote itself is out of date. To fix, put remote in pairing mode by holding play/pause button for 5 seconds. Then, instead of adding a remote, use the Alexa app to pair a standard Bluetooth device for the echo you want the remote paired to. You should see an option to connect a device with “remote" in its name. As soon as you select that device your echo will likely tell you the remote needs a software update and it will start that process for you. When it completes, the remote should automatically be paired with the echo.
このアンサーは役に立ちましたか?
スコア 15
14 件のコメント:
I tried those steps and still no luck. I think the app might of updated and messed up something.
さんによる
This worked for me, except it didn't show the device name, just it's Bluetooth MAC address (xx:xx:xx:xx:xx:xx); as soon as I paired it, my Echo Studio started the software update and the remote worked afterwards!
さんによる
I tried so many other methods and just about gave up. This worked great.
Unknown Device popped up and I paied it. It immediately worked.
さんによる
OMG!! I spent all day trying EVERYTHING until I came upon this post. Worked perfectly!! I was going crazy! Thank you!!!
さんによる
Also... I looked all over Amazon help and they did not have this solution. Again, many thanks! : )
さんによる
9件以上のコメントを表示
コメントを追加
  • Check that the remote has a fresh pair of AAA batteries.
  • Go to Settings > Pair remote in the Alexa app, and then press and hold the remote's Play / Pause button for five seconds while Amazon Echo is searching.
  • If you see a purple spinning light on your device, more than one remote was found. Press the Play / Pause button on the remote you want to connect with.
Note: The Amazon Echo Remote is sold seperately. Only one Amazon Echo Remote can be paired with Amazon Echo at a time.
このアンサーは役に立ちましたか?
スコア 2
7 件のコメント:
Very good response! I would have added a link to the correct controller.
さんによる
This response is really reiterating the instructions from the app, it is not helpful when you follow the instructions and it still won't pair.
The Alexa app recently updated. I have tried many times, many types of quality batteries, holding the remote at different angles, pressing play for 5, 10, even 20 seconds nothing.
The question was what do you do when the remote does not pair, not what are the standard instructions to pair.
さんによる
I was having the same problem. I just unplugged the echo dot and plugged it back in and i was able to set up the remote. Maybe it’s worth a try.
さんによる
I also have this problem, Amazon says it should still work with the echo. I did everything I have three remotes now and none work. I think the app update is the culprit.
さんによる
Bingo - Amazon should clue Echo users on this tip.
さんによる
2件以上のコメントを表示
コメントを追加
Above steps helpful for pairing remote with Amazon Echo.
However, in case if Alexa fails to hear your voice commands because the music’s too loud or because you’re sitting in a different room, you can now use the Amazon Echo Remote to communicate with Amazon Echo, and get things done.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
There are two ways to pair an Echo Dot to a firestick.
The first way doesn't seem to work. In the Alexa app, when you go to devices and select your Echo Dot, it says you can link it to an echo remote. When you do this, it says to hold the play button for 5 seconds and this does not work. I've tried a hundred times by now.
The second way does work. In the Amazon app, go to More -> Settings. Scroll down to TV and Video. Select FireTV. Select Link or Manage Devices. I already have 3 dots linked to 3 different firesticks, so my options here may be a little different than yours. From here I select to "link another device". If it is your first link, it might just say "link device". Click to link another device. It will have you first select the Firestick you want to pair. Then it will show you a list of devices where you will select your Echo Dot.
That's it!
Now your Echo Dot will accept voice commands to control your FireTV.
さんによる
コメントを追加
That's it!
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
alfarsi1993 さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 8
過去 30 日: 47
今までの合計 12,404
