Two apps working simultaneously on the screen
I have heard that it is possible to open two apps at the same time. Is this possible and how can this be done?
Yes, this computer allows you to use apps simultaneously. Not only can you have 2 apps running at the same time but you can also see them at the same time in the screen. You can have up to 3 apps working together. To do this open an app from the Start screen. Go back to the Start screen and open another app. Using the trackpad swipe right from the left edge of the screen to display the last app that was opened. Swipe right from the left edge of the screen until you see a column divider to display both apps at the same time. When opening three apps, three columns would be needed.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 62
