メインコンテンツにスキップ
締切られた回答
Problem with LCD Screen
Need a little help with a recent screen problem with my Samsung UE46ES7000, I have searched the web but can't seem to find a similar problem to mine.
I recently moved house and in transporting the TV I think it might of got bumped around the screen area, and when I turned the TV on it started flickering, then settled down and then a black blurred bar appeared across the screen (see Picture).
What I have found is when I turn the TV on, the picture is fine and then after 10minutes or so the bar appears again.
I have been pointed in the direction of the T-con but just wanted to throw it out their to see if anyone might of experienced the same kind of problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
最も参考になった回答
It sounds like it could be an issue with either the T-con board or the motherboard. If you haven't already, I would open the TV up and check the connections on the T-con and the lcd screen as a cable could've come loose during transportation.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 518
