Ipad 4 digitizer ghost touch (keeps moving by it self)
Hey,
I have replaced my iPad 4 digitizer and it has been spassing(moving by it sself) out. it seems to be getting worse and worse. i need help quick
この質問は役に立ちましたか?
Hey,
この質問は役に立ちましたか?
Try disconnecting the LCD and the touch Screen
Reconnect the LCD and touch Screen to see if the problem is still there.
IF the problem is still there then you would need to buy another Touch screen. and try it with the new one
There are rare occasions where the touch screen u bought will be a defect. (happened to me before)
このアンサーは役に立ちましたか?
Where did you purchase the screen at, those cheap eBay screens will only cause you problems. I also use kapton tape around the inside of the screen to cover the metal edge that comes in contact with the metal frame when the screen is put down. Try a screen from Ifixit and see what happens, also to save some time you can buy adhesive called bowler tech that is precut and applies to the frame, never had a screen lift with this stuff.
このアンサーは役に立ちましたか?
i've seen this method(have not tried it yet.) i am waiting for the kapton tape to arrive(thursday) then ill post feedback.
Most likely 90% of ghost touch is defective touch screen, return and exchange it under a warranty and replace. Also test screen before putting back together to make sure the digitizer cable is not defective as well.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 204
