メインコンテンツにスキップ
これはHP Photosmart Premium e-オールインワンプリンターです。 モデル番号はC310a。 製品番号:CN504A。
20回答 すべてを表示
It won't print its got ink it just won't print why
Please can anyone help me my printer won't print its got new ink and it works but when i press print on my computer the printer turns on it looks as if its printing but when it spits it out the paper is blank why?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
Hi,
Just curious, does it print OK if you make a copy of a document, using the control panel of the printer? If it does what OS is installed in your PC?
さんによる
コメントを追加
1 件の回答
最も参考になった回答
It sounds like the head is blocked. Are you using aftermarket inks? as this can cause damage to print heads (which is almost irreversible without replacing the head, which is so expensive buying another printer is often a batter option)
Assuming you are not using aftermarket inks, or that this happened after a warm day or a period of sitting, try doing a head clean.
This can either be done via the printers menu or via printer properties on the computer. It sometimes needs to be done several times. More information here:
http://h30434.www3.hp.com/t5/Inkjet-Prin...
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Claudia ordonez さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 4
今までの合計 492
