Why is there no sound when I make a video?
When I play my recorded videos, I can never hear any feedback.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi,
1. On playback, have you ensured that the Volume is turned up?
This shows how to adjust (step 5) and where to check on the screen (See #9 on picture)
2. Have you ensured that the microphone is not covered? This shows its' location.
(click on images)
このアンサーは役に立ちましたか?
If you have the waterproof case on, you more than likely won't be able to hear any sound since sound can't get to the microphone. Boo.
If you have the case off and still cannot hear anything, please make sure you have the volume turned up on the playback mode!
このアンサーは役に立ちましたか?
wont work help me!!!
It’s not working
Mine worked with the case. When I tried again without the case I had no sound. I discovered that the voice record has to be off ( x through the mic symbol) . Now it's working again 😁
このアンサーは役に立ちましたか?
過去 24時間: 1
過去 7 日: 2
過去 30 日: 11
今までの合計 9,815
