メインコンテンツにスキップ
モデル番号A1502/2.6GHz(Turbo Boost使用時最大3.1GHz)もしくは2.8GHzTurbo Boost使用時最大3.3GHz)デュアルコアIntel Core i7、4MB共有L3キャッシュに変更可能
494回答 すべてを表示
Keyboard glitches out and trackpad doesn't work
Hi,
I am having some issues with my MBPr, The trackpad all of a sudden stopped working and the keyboard glitches out. I restored the computer to factory default, it did not help. Is the issue most likely the keyboard connector and trackpad connector disconnected or could it be that the whole top case was ruined somehow?
Thanks,
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Check it for a swollen battery.
このアンサーは役に立ちましたか?
スコア 4
2 件のコメント:
And you tell me to explain the problem even more and put links and stuff yet look at your answer
さんによる
The irony here makes me smirk. :)
さんによる
コメントを追加
Expanding on @Mayer's answer, there's a valid chance that it's a swollen battery, or a faulty Trackpad.
CoconutBattery 3.3 is the current version, and it's a good tool for assessing battery problems.
http://www.coconut-flavour.com/coconutba...
iFixit's Guide to 2014 Retina Battery Removal:
MacBook Pro 13" Retina Display Mid 2014 のバッテリーの交換
First, use that program and see if "Service battery" or anything other than Good is listed. Design Capacity should be high, too.
Second, as a diagnostic, open your retina and loosen the battery screws as much as you can, relieving any pressure from a swollen battery, and see if the trackpad gains some sanity. If it does, time for a new battery. If it doesn't, it's a trackpad.
このアンサーは役に立ちましたか?
スコア 2
2 件のコメント:
Obviously I'm going to have to do a guide on how to get this battery out in a quarter of the time the iFixit staff does it.
さんによる
that's why we're here, right? :D
PS, I voted your answer as helpful; though short, it was the best concept.
さんによる
コメントを追加
回答を追加する
Masoud Harati さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 1
過去 30 日: 2
今までの合計 389
