Why does Sensor panal malfunction
Panel resets all the time it comes up with close door and select food setting after unplugging unit from a.c. I can reset clock and get it to work once then the panal will revert back to close door and then ask to select food type 1-6. What needs to be done
edroberts43 you said that "after unplugging unit from a.c." does that mean you unplug it after using it? I am a bit confused by that. What model is your MW?
oldturkey03 さんによる
After the microwave malfunctions iIunplug the unit and I then plug it back in and am able to reset the panel my microwave is a G E s/n JVM172QP1WW
edroberts43 さんによる
After you plug it back in then you get the error? Or do you get it after you set the time etc. and run it once? Have you consider that it is a faulty door switch?
oldturkey03 さんによる
