broken screen and digitizer
The screen & digitizer on my blu phone is broke, how much will it cost to fix it &can I do it myself
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Hi Chastity,
The parts for your phone are available on Amazon and range anywhere from $12-$40. Be sure to verify that the part you order will work for your specific model. The compatible model numbers are listed in the product description. Here's a link to the BLU Studio 5.0 C HD parts on Amazon.
Many companies that sell these replacment parts recommend going to a professional installer for this fix, but we think you have what it takes to fix it yourself. Although there isn't a specific guide for your phone on iFixit, you can check out the screen replacment guide to a similar model here to get an idea of how to replace the screen. As for the digitizer, once you get the phone open you can see what it may take to replace the part. It could be a few simple ribbon cables and screws to remove the digitizer, but if it seems too complicated you can get help by taking it to a local cell phone repair shop in your area. If you decide to take on the repair yourself, make a guide for it on iFixit so you can help others with the same problem.
Good Luck!
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 1
今までの合計 849
