メインコンテンツにスキップ
The Inspiron 15-3521 has an optional touch screen feature and has a 15.6" display. This laptop is also complete with a matte finish and keyboard complete with number pad.
40回答 すべてを表示
No Boot Device Found
Just replaced my hard drive with a new one from ifixit, when running diagnostics it now shows no errors when previously it said there was a problem with the hard drive. On boot up it states: No Boot Device Found. Press any key to reboot machine
On the boot menu after pressing F2, I only have the following options:
LEGACY BOOT: (which is gray)
UEFI BOOT:
When selecting UEFI BOOT:
UEFI Onboard LAN IPv4
UEFI Onboard LAN IPv6
It doesn't seem to matter which order they are in
After reading all other forums, I have not found a solution to this.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
did you format your drive re-install your Operating system on the new hard drive? When you boot to BIOS check if the hard drive is getting detected there or not. Here are the steps:
Restart the system and immediately start tapping the 'F2' key to enter the 'BIOS'.
Please check what is written next to 'Fixed HDD'.
Double check your installation and your drives compatibility
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
So if I enter f2 and enter bio what next, because my dell is still on fixed HDD ( not detected) . What should I do next?
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
tucrkilerita what is your computers make and model? This is a new hard drive?
さんによる
コメントを追加
回答を追加する
Karen Chandler さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 12
今までの合計 14,691
