メインコンテンツにスキップ
締切られた回答
GB Micro blank/black screen
So, I found my GB Micro recently and found that it doesn't work. I've fully charged the device and get the same result whether its plugged in or not.
Upon turning the device on, the Select and Start buttons will turn blue for 2-seconds and then quickly blink (still blue) three times and 3-seconds following that, the Select/Start led turn off. During this, the back-light comes on, but the display is black. I've already tried replacing the battery.
Video here: https://www.youtube.com/watch?v=RC6EgFjl....
Anyone here have ideas?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 0
コメントを追加
1 件の回答
its probably because you havent used it in a while or it is worn out i would suggest take it to get it looked at.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
No idea where I would take it. Usually when something stops working, you should be able to find and replace that non-working part to get everything up and running.
さんによる
コメントを追加
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 275
