Looking for a screen replacement.
I cracked my screen on the Huawei Honor 5X and would like instructions on how to fix it and where I could get a replacement screen?
You have to replace your Huawei Honor 5X Screen from Services center.
このアンサーは役に立ちましたか?
thanks it worked
I accidentally put the micro SD directly inside the slot without SIM card holder. How do I fix this?
このアンサーは役に立ちましたか?
Watch full pictorial view at Huawei Honor5X Manual.
このアンサーは役に立ちましたか?
is there any place I can get it fixed or what should I buy and do to fix my shattered screen? Also can I change the color of my honor 5x from white to black from this?
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 5
今までの合計 5,524
2 件のコメント
I found a couple of places go get the LCD and glass digitizer, and some instructions on Jerryrig Everything. I will be doing the repair when my parts get here, and I can take some pictures and walk through it myself if that would help
derudy237 さんによる
On ebay I found a screen and digitizer combo and that worked best for me. I have only replaced a screen on one other phone and found that for the Honor 5X it is best to replace the screen and digitizer together. I also saw the video from Jerryrig Everything and while very helpful he is taking the whole phone apart which after the fact I found out is overkill for replacing the screen and digitizer. Let me know how your replacement goes. I am now having trouble with the fingerprint sensor. I don't know if it was due to how I put the phone back together or not.
gregpif さんによる
