I can not call with my phone?
I can call people and I can hear them speaking but when I try and talk there is a lot of static and they can barley hear my voice. I try to talk to Siri but she cannot understand anything?
Sounds like your microphone might be bad. Try the voice recorder app on the phone and see if it's clear. Check the microphone area too and see if there's any dust clogged.
このアンサーは役に立ちましたか?
I cleaned out the microphone area but didn't fix anything and when I use the voice recorder app all I hear is static
It might need to be replaced then. But before doing so, try a pair of apple earphones and use the mic on that. If it works, then you might need to replace the microphone in the phone.
I had a problem when the lag call recorder. I set another application to record and everything was working
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 51
