メインコンテンツにスキップ
3.28 Megapixel camcorder released in March of 2014. Identified by part number 9176b001.
10回答 すべてを表示
Water Vapor on the camera lens.
I took my camcorder outside and it stared raining. Now whenever I use my camera the lens is foggy and I'm not able to see clearly on the device. Did me taking my camera outside permanently damage my camera? If not how can I fix this problem?
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
最も参考になった回答
Water entering your camera can leave smudges on the interior of your lens that you can not clean. Do not attempt to use a hair dryer to dry your camera. You can try placing your camera in a bag of rice to see if this resolves your problem.
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
id reccomend taking the thing appart, and try to clean the lens, it could also be (if your device has optical focus (identifyable by faint clicking noises when it focusus) and water coming in there, and leaving ressidue in the mechanism, this can be fixed by washing yoour immage sensor in 96% alcohol in a super clean container, and let it dry out (make shure to not add any impuritys to the alcohol like water or using a container with impuritys in it
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
Deion Woods さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 4
今までの合計 448
