How can I get batteries for XTouch X2?
I need XTouch X2 bvatteries for 3 of my XTouch X2 phones,
I have seen these batteries on amazon for under $10.00, hope this helps.
このアンサーは役に立ちましたか?
hii,
Looking for a replacement battery for your Xtouch X2? Battery for Xtouch X2 is the perfect high quality replacement battery specially designed for your handset to solve the problems of quick battery drainage, low backup time or even extend the usage time by keeping an extra stand-by battery with you.
Xtouch X2 is a great phone with great features, but low battery backup time can be really annoying when in need. Buy our high quality battery pack & replace it with your existing damaged / low backup battery & unleash the full performance and maximum up-time of your handset.
This battery is standard & similar battery that is used for Xtouch X2, so you need not be worried that the new battery would damage your expensive phone in anyway. The battery has been specifically designed for your Xtouch X2 and comes with performance even better than the original battery that was shipped to you with the phone at first.
Thanks!
I didn't find the right solution from the Internet.
References: https://www.maxbhi.com/battery-for-xtouc...
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 7
今までの合計 1,439
i can't found Battery model NO: B4
battery for X4
rogeh さんによる
