メインコンテンツにスキップ
The Dell Dimension 2400 is a desktop computer released in 2003 with a traditional box "tower" form factor and a black exterior. It is the last machine from the Dimension 2xxx series and is equipped with a Celeron or Pentium 4 processor.
13回答 すべてを表示
Can anyone provide ideas on why my computer will not start?
The computer will not turn on at all. I do not know if some wires have short circulated or if there is a problem with the power source. Can someone give me tips about diagnostic procedures?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
1件のコメント
@unnymonkey what have you tried? Do you have a multimeter? Have you checked the PSU? You will need to give a bit more information.....
Rep: 1
さんによる
コメントを追加
1 件の回答
ベストアンサー
Start with the a static discharge and work from there . Unplug the computer and hold the power button down for 60 seconds. then plug in the computer and try it .If this brings no joy try removing the ram and trying it with 1 stick at a time .there could be a bad dimm and one will keep the computer from running . If your board is equipped with a mem refresh button now would be a good time to push that. If no joy is near now try replacing the power supply . If you still have no joy then you may need to look at the motherboard or processor. Hope this helps keep us posted
このアンサーは役に立ちましたか?
スコア 3
コメントを追加
回答を追加する
Albert Einsteain さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 19
今までの合計 642
