メインコンテンツにスキップ
モデル番号A1286、発売日 2011年2月/2.0, 2.2もしくは2.3 GHzクアッドコアIntel Core i7プロセッサ
586回答 すべてを表示
MacBook battery doesn't work after RAM upgrade, no chime
I just followed the guide for replace my MacBook Pro RAM from 4GB to 8GB (one chip), when I reconnected the battary it won't work and my Mac won't startup! The battary light indicator isn't showing any light, when I connect to Magsafe to power source it lights in green but still not charging nor starting up. Can someone help me where did it go wrong and how to fix it?
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 1
コメントを追加
2件の回答
ベストアンサー
The RAM upgrade probably had nothing to do with it. Most likely is that you unplugged the battery for the installation and failed to plug it back in. You might have bent a pin.
このアンサーは役に立ちましたか?
スコア 2
9 件のコメント:
@mayer How can I ensure that I plug it back in correctly? All pins look perfectly fine to me.
It's very straight forward task!
Also I'm unable to boot the device when connected to external power source. I'm using 60W MagSafe adaptor.
さんによる
Switch the old RAM back. Have you had any prior issues, any video issues at all?
さんによる
@mayer I already tried that still the same. No significant at all.
さんによる
Did you turn the system off fully before taking the RAM out (disconnect the battery)? If the system was still powered when you pulled the RAM you could have damaged the logic board.
Also, did you practice good ESD protection? It's winter with dry air static is a killer as well.
さんによる
@danj Yes it was fully shut down, then I disconnected the battery.
Um I'm not sure what I was supposed to do to ensure ESD protection?
BTW I removed the old RAM and put it back in couple of times, before I inserted the new RAM chips. The only difference is that this time I disconnected the battery. When I was experiencing with the old RAM (removed one and left one, then put them both back) I didn't face any issues and my system recognized these changes.
さんによる
4件以上のコメントを表示
コメントを追加
You be sure the firmware update is correctly.
First you need do a PRAM with the machine connected to power.
That is done with the folowing secuence : Command (cmd) + Option (alt) + P + R on a keyboard inmediatly after power on.
Hear 3 beep, following hold off the keys, is the computer didnt startup , may be the damage is more deep and sugest go to a service center.
PD try without battery.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
@irepair I can't do a PRAM, It won't power on with or without battery.
さんによる
コメントを追加
回答を追加する
r1m111 さん、ありがとうございました!
統計データ:
過去 24時間: 2
過去 7 日: 5
過去 30 日: 5
今までの合計 283
