Help identify iPhone 5 missing components
Hello,
anyone can help me identifyng these two missing components on this Iphone 5 board?
Thanks.
Hi!
1. can you attach a wider image with an arrow pointing towards the area
display connector area?
if so
it looks like the C192, C202 capacitors
and you can find them here
http://www.digikey.com/product-detail/en...
2. from the attached schematics can you identify it?
このアンサーは役に立ちましたか?
just to make a note these capacitors are very small
and very hard to solder
if you are going to try a couple of basic things
1. you may make your situation worse
2.soldering iron needs to be hot
3. you will need a good solder
4. and a steady set of hands
Thanks for the reply .
This is the front camera connector area , I forgot to say , I apologize ..
Welding skills are not a problem for me .
I have already seen that the schematics , but the logic board is slightly different, as you can see below :(
このアンサーは役に立ちましたか?
i do not this they are different?
if it because of the U16 chip you think they are different ?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 179
