Taking apart the Logitech M280 aka M320
Does anybody have any idea on how to disassemble this mouse? I'd like to replace the switches inside of it, but I can't seem to find any screw holes, even under the feet of the mouse.
この質問は役に立ちましたか?
この質問は役に立ちましたか?
The M280 has a single screw below the battery. It is covered by a black sticker somewhere in between the + and - signs. I scratched the area with my nail and a circular area appeared indicating a screw hole. I removed the screw and the was able to take the thing apart for cleaning. Hope this helps.
このアンサーは役に立ちましたか?
Yup, this helps!
Thank You, it works!
Thank you very much!!!
thanks it works :D
There is a single screw seen when you takeout the battery and the sticker below. one can scratch open the sticker close to the side middle of battery symbol.
hello, you should try this video: https://www.youtube.com/watch?v=hxhF5F5F...
このアンサーは役に立ちましたか?
Hi Yang Ho
There should be 2 screws where the legs are and one next to the battery. I haven't personally open one of them but I have opened different ones.
Hope this help
このアンサーは役に立ちましたか?
I tried taking the feet off, and removing the battery and almost everything that could be covering screw holes (including stickers) but there's nothing of the sort :(
I know what you mean though, as I've taken apart a lot of Logitech mice before easily. This is the first one I'm having difficulties with
Sorry I couldn't help
過去 24時間: 0
過去 7 日: 9
過去 30 日: 51
今までの合計 8,029
