How do I wire a tachometer
how do i wire a tachometer on a 1993 jeep grand cherokee
この質問は役に立ちましたか?
この質問は役に立ちましたか?
jimmiller1940, as a general answer since we do not know which tach you have, most aftermarket tachometers only have 3 or 4 wires that need to be connected. Usually a green wire for the tach, red for power, black for ground, and white or yellow for the back light. The power wire that gets connected to a 12 volt ignition source, the tach signal wire that connects to the coil or the designated signal wire in your cars wiring diagram.
このアンサーは役に立ちましたか?
過去 24時間: 2
過去 7 日: 3
過去 30 日: 8
今までの合計 948
1件のコメント
what make and model is your Tach? Post some images of the connectors with your question. Use this guide iFixitでの質問に画像を追加する方法 for that
oldturkey03 さんによる
