To remove the cover of tomtom start 50
How to remove the cover of tomtom start 50 model which doesn't have any screws visible?
New unit. Screen cracked.To check the serial number of led to order on eBay.
Thanks
この質問は役に立ちましたか?
Thanks
この質問は役に立ちましたか?
You can find the disassembly video How to Replace Your TomTom Start 50 Battery, which is a good teardown of the device.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 1
過去 30 日: 1
今までの合計 1,574
2 件のコメント
Thanks Abdur Rahman... but my model doesn't have any screws visible on it.. different type.
afsar cm さんによる
If there are no screws under the manufacturer label on the bottom, is there a mound socket on the back. On the TomTom Start 60 there is one. Both videos show using an open pry tool between the back and front of the display, so if you can not find any screws, there may be latches that hold it together.
Abdur Rahman さんによる
