メインコンテンツにスキップ
Furby was a popular electronic robotic toy resembling a hamster/owl-like creature which went through a period of being a "must-have" toy following its launch in the holiday season of 1998, with continual sales until 2000. Furbies sold 1.8 million units in 1998, 14 million units in 1999, and altogether in its three years of original production, Furbies sold over 40 million units.
85回答 すべてを表示
My Furby is not moving much and goes sleeping after 1 minute
My daughter's Furby just started to make this cracking noise with every word it says. Also the Furby's moving very quietly and not moving back and forward (at all).
Usually when the Furby goes to sleep, it will bend forward. Also the its ears (SOMETIMES) are not moving forward when going to sleep.
When the Furby is awake, it will last like 1 minute and its eyes will light off (and will go to sleep). It will only wake up if I shake it well.
I also noticed that will not react fast/properly when touching him.
The reset (or the change of personality modus which ONLY WENT GO 1 TIME)won't help.
I kindly ask for help. I speak also NL, ES and IT.
Thanx!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
3件の回答
My furby keeps falling asleep
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
There might be a loose wire. Also check the batteries. In the image that I linked there is a diagram that shows where the reset is located on your furby model.
https://static.wikia.nocookie.net/offici...
さんによる
コメントを追加
Checking the wire properly.. Some Wire burning and need to replace.. Becareful for replacement.. Very difficult.. Also checking. Dc motor running
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
The small 6V brushless DC motor went wrong.I’ve had similar issues to this as well. You can replace it with one from a PC DVD reader (the door opener motor). Shaft is smaller but it's ok, diameter is good. You’ll need a soldering gun.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Ciro Morante さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 6
今までの合計 1,415
