メインコンテンツにスキップ
リペアコミュニティに参加 - アカウントの作成
2015年3月に発表され、同年4月10日に発売されました。Galaxy S6 Edgeは Samsungの最新のスマートフォンで曲面ディスプレイをもつデバイスです。
Microphone not working after charging port replacement
Hello,
I have changed the microphone / charging port on my S6 Edge. Now the microphone is very fuzzy and people can barely hear me when i'm talking over the phone. Everything else is working fine. The repair went smoothly as I've fixed quite a few of these before.
Has anyone else had this problem? I'm guessing it could be different rev. numbers on the part. Although I binned the old one and cant find out which version it was.
Any help will be greatly appreciated.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
1件のコメント
So you've taken apart a few of these? Where did you order replacement adhesive from?
さんによる
コメントを追加
4件の回答
ベストアンサー
If it's not OEM, it's common for the replacement headphone ports/mic to be bad.
Just get another replacement, chances are it will be better.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
I'll give that a go and let yous know. Thanks for the quick reply.
さんによる
コメントを追加
OK so after trying 2 different charging ports / microphones. The problem was still there. I tried one more from another supplier and it worked fine. Seems like there are quite a few faulty ones going around. Thanks again
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Can you please help me, my s6 edge plus stops working the mic, what flex cable should i buy? regards
さんによる
コメントを追加
Hey did you ever fix your mic issue. I have used the earrings ...no good factory reset.. No good... Took Sim out and no good.. Ugh help me somebody please
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
Yes, he did.
"OK so after trying 2 different charging ports / microphones. The problem was still there. I tried one more from another supplier and it worked fine. Seems like there are quite a few faulty ones going around. Thanks again"
さんによる
コメントを追加
The same problem so after trying 4 different charging ports / microphones. The problem was still there.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Peter N さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 12
過去 30 日: 25
今までの合計 4,745
