メインコンテンツにスキップ
A 4 Amp corded power drill released in June 2014 by Black and Decker. The corded device is a part of the Matrix Quick Connect System which enables various attachments.
How can I switch the direction on the drill?
I need to unscrew a misplaced screw but I don't know how to switch it into a reverse position.
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 5
2 件のコメント
please tell me how the reverse mechanism works in bosch gsw 450re , because it isnt working in my machine ..
さんによる
How to take a screw put w/ a 1/4in single speed drill by black &decker
さんによる
コメントを追加
2件の回答
ベストアンサー
In order to change the direction of torque, fully toggle the switch above the trigger into the alternative position.
このアンサーは役に立ちましたか?
スコア 3
1件のコメント:
Hi does a black and decker bd163va have reverse.or what is the black round button for near trigger
さんによる
コメントを追加
I have a domestic 450w Black & Decker electric drill that does not have a reverse switch, yet it is turning anti-clockwise. Mind you, I lent this driller to someone who returned it long ago, but now I wished to use it in lieu of the other two that I have and discovered that it has started to turn anti-clocwise with the result that the chuck unwinds. Please can i repair it as it is adequate for me.
Update (02/09/2017)
I do not know if he repaired it or not, because he passed away.
Update (02/09/2017)
Re Black & Decker drill, it only has a common switch and a sideway button which when pressed while drill is functioning will render drill functioning automatically. Again, please anyone with a correct answer? Thanks beforehand.
Update (02/09/2017)
Hi Mr Edgardo Gutierrez thank you for your answer. But my drill has a common switch.
このアンサーは役に立ちましたか?
スコア 0
1件のコメント:
It is possible to change the direction by reversing the brush connection which will be internal to the machine. Need electrical knowledge to do so.
さんによる
コメントを追加
回答を追加する
Tyler Yurina さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 8
過去 30 日: 50
今までの合計 49,578
