help with wifi hardware
hey
i would like to know the wifi hardware on the hoc one m7
as its very week to detect the wifi
to connect i need to be just few cm near the router or it will not work thanks
hey it works only when am in few cm from the router my phone had been prepared so i think some thing not okey on the hardware maybe not correctly attached its on auto mode so its both are selection 2.4 and 5 ghz
このアンサーは役に立ちましたか?
Hi,
Looks like you are right. Maybe you should take it back to the repairer and get them to check their work.
過去 24時間: 0
過去 7 日: 2
過去 30 日: 6
今までの合計 115
Hi,
Have you tried connecting to a different router? Does it 'pick' up other networks (I know that you cannot connect to them). Are you trying to connect to 2.4GHz or 5GHz WiFi?
jayeff さんによる
hey
attiouim さんによる
Hi,
Can you detect other routers or not?
jayeff さんによる
yes but only if am near (less than 1 meter )
attiouim さんによる
