Device will not power on after battery replacement
I purchased a replacement battery from ifixit, and followed the teardown. All went smoothly, phone is reassembled now. When I plug in the micro USB, the screen lights up with the charging indicator.
When I press the power button, the phone does not power up. I was careful when prying off the back cover, avoiding the ribbon for the power/volume buttons.
Any thoughts?
この質問は役に立ちましたか?
Hi, Is the battery sufficiently charged? Hopefully your charger has enough output to run the phone and charge a low battery (if that is the problem)
jayeff さんによる
Hi, thank you for the response. The charge indicator shows beyond 75%. The phone does not power up with USB plugged in or unplugged.
kc7eph さんによる
