My phone seems to have a mind of its own
When I try to unlock my phone, it will either hit number I do not hit or delete numbers I have hit. It is like my phone does what it wants now, and I do not what caused this. HELP???
Can you provide the history of the phone? Has it had a screen replacement? Often the new screen can 'ghost' which appears to touch wherever you want. It's also worth checking the LCD flex on the screen if so, as this should have a piece of tape over 3 exposed solder joints.
このアンサーは役に立ちましたか?
Try checking in your settings if you can adjust the screen sensitivity because some screens are very sensitive so like if you have oily hands or just any form of moist on your screen it might click another thing instead of the one you actually clicked/pressed if that makes any sense
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 3
今までの合計 267
