Nintendo DS Lite Will not turn on
So about a month after I got a Nintendo DS Lite motherboard and installed it, It would not turn on or charge. When I plug it in, the charge light turns on for about a second and then turns off, and when I push the power switch up, Nothing happens whatsoever. Both fuses are good(0 ohms), and L2 reads fine, there is continuity between the power switch and pin 12 (PWSW) of the power management IC. I have another DS Lite motherboard that will charge but will not turn on (both fuses good), and the game card slot is taken off. So I have a parts motherboard if I need it. Help will be greatly appreciated because I really need to do my daily Brain Age.
Do you have a spare battery that you can test the DS Lite with?
Abdur Rahman さんによる
Yes I do, still does not work. It is supposed to turn on even with no battery when plugged into charger. (and yes the charger is good.)
Nathaniel Clark さんによる
I am sorry, I have the same problem with mine, too. If I find out how to fix it, you will be the first person I tell.
Jolie Summers さんによる
