メインコンテンツにスキップ
2010年4月発売。2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7プロセッサ
590回答 すべてを表示
Mac not charging after minor water damage
Hi guys.
I've got a friend's mac that got given to me to have a look at. The mac at first was not starting up at all after a water spill.
The laptop was then disassembled and thoroughly cleaned with alcohol to ensure there was not water residue left on the logic board.
I replaced the battery, and the DC jack. After replacing the battery the macbook started up without any problems.
My only problem is that, after trying 3 separate chargers (known to be working on other macs) the light on neither chargers will light up!
I don't have ANY colour light showing. Any one able to point me to what chip might needing to be replaced (if any) or if there's any tricks with the macbook chargers? I'm not too savvy with macs I repair windows laptops mainly.
I've cleaned the logic board about 3 times now without ANY sign of corrosion at all. Every chip looks to be fine (well as far as what my eyes can see).
Looking forward to a reply, peace.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
最も参考になった回答
Trying to tell you exactly what chip needing replacing is toooo vast! It could be the chip, resistors ,caps or inductors or even shorted traces that require jumps. You need to search the net for boardview and schematic for your board and check for short to ground with multimeter youtube can help if you look right. No light on the magsafe usually means the one wire over voltage is not working , feel around on the board and see also if there is area that is super super hot obviously this means the circuit is shorted. That's all I can do this is a very simple answer to a very in depth answer. Good luck!
このアンサーは役に立ちましたか?
スコア 1
コメントを追加
回答を追加する
sxcchaldo69 さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 0
過去 30 日: 0
今までの合計 118
