メインコンテンツにスキップ
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
140回答 すべてを表示
Starbucks Barista primer not working
My Starbucks Barista machine has no water coming out. There is plenty of water in tank. Steaming function of machine still seems to work, though not as strong. Tried to follow the priming instructions, but doesn't help...never get any 4 ounces of water to flow through the steam wand as instructions state. Just a trickle of water, then steam.
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
1 件の回答
最も参考になった回答
If you haven't descaled the boiler within the last few months then you may have some calcium build-up that is constricting the water passages or pump; you're only getting a little steam out because what little water is making it into the boiler is being vaporized. Be careful leaving the machine on for too long in this state as an empty boiler can quickly lead to overheating and a ruptured heating element.
このアンサーは役に立ちましたか?
スコア 1
1件のコメント:
さんによる
コメントを追加
回答を追加する
rob さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 3,060
