メインコンテンツにスキップ
2013年9月10日に発表されたApple iPhone 5sの修理情報とガイドです。モデル A1533、A1453、A1457、A1528、A1530、A1518。
3530回答 すべてを表示
Will not slide to unlock
When I try to slide to set up my iPhone 5s it doesn't respond. I've done the hard reset and nothing works. It also says hello in the center of the screen and where it says 'hello' and 'slide to set up' it keeps changing to different languages. Please help!
この質問に回答する 同じ問題があります
この質問は役に立ちましたか?
スコア -1
コメントを追加
1 件の回答
I'm assuming you've waited for a while - sometimes they won't respond for a 30-60seconds or so after booting. If so, the digitizer is not working on the display. It could be a faulty display, but often it's just that it got disconnected. Follow these instructions steps 1-15. Notice the last thing you disconnected was the digitizer. Check the cables and connectors for dirt or pieces of glass or similar that could sit inside and keep the connector from fully seating - clean it out with air and/or alcohol swabs. Then click the cables back on the connectors in the reverse order of steps 13-15. You can now turn the phone back on and see if it's working. If it is working, make sure you have some not-conductive spacer on the back of the connector before you reassemble (see the foam in the pictures above - that puts pressure on the cable to keep it from popping off, and replacement screens often don't have it).
If it still isn't working you have either a faulty screen or a more serious problem on the logic board.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
Wes Jones さん、ありがとうございました!
統計データ:
過去 24時間: 1
過去 7 日: 2
過去 30 日: 2
今までの合計 167
