Why will my booklet connect to wifi but not the internet
My wifi has a healthy connection but when it it goes to the internet it will not connect
この質問は役に立ちましたか?
この質問は役に立ちましたか?
Is our router connected to the internet? it is possible to use a router to create a network without it being connected to the internet. You could also try renewing and flushing dns
Select Command Prompt (Run as Administrator).
Type ipconfig /release in the command prompt. then press enter
Wait a few seconds for a reply that the IP address has been released.
Type ipconfig /renew in the command prompt. then press enter
Wait a few seconds for a reply that the IP address has been re-established.
Type ipconfig /flushdns in the command prompt. then press enter
Close the command prompt and attempt to make a connection.
Hope this helps
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 2
過去 30 日: 5
今までの合計 530
