メインコンテンツにスキップ
モデル番号A1502 / 2.4, 2.6, 2.8 GHz デュアルコアIntelプロセッサ/ 2013年10月発売
552回答 すべてを表示
Liquid damage - is it the battery or the logic board?
H i,
there was coffee spilled on my MacBook near the fan. It still works fine with the AC adapter, but the battery seems to be broken. Also, the battery symbol says that the battery has to be exchanged.
My questions:
- Do you assume it's rather the battery or the logic board that is broken?
- Sometimes (especially after using it for a while) the MacBook seems to work slower or have glitches. Why do you think is this?
Thanks a lot in advance,
Sebastian
回答がありました! 回答を表示 同じ問題があります
この質問は役に立ちましたか?
スコア 2
コメントを追加
2件の回答
ベストアンサー
I would dissasemble and check it, no point in risking it letting corrosion build up.
Clean it all with 99.9% isopropyl alcohol, and a toothbrush.
Or go for the more professional approach and get a shop with a good ultrasonic cleaner etc. :-)
I would also replace battery if it has been effected.
このアンサーは役に立ちましたか?
スコア 2
コメントを追加
I had the same happen. I had to replace the keyboard, battery, and logic board. Probably cheaper to buy a new one. I am in Canada and it was $1100 to replace those parts.
このアンサーは役に立ちましたか?
スコア 0
コメントを追加
回答を追加する
sebastian さん、ありがとうございました!
統計データ:
過去 24時間: 0
過去 7 日: 1
過去 30 日: 2
今までの合計 448
