boots then shuts down and powers off
device shows power but shuts down on its own, behaves intermittantely when reboot or starting up
I have the same problem with my tablet. There's a permanent solution and a temporary solution; the temporary solution is to unplug the screen via the ribbon cable while it charges for a while, then plug it back in. The permanent solution is to get a new battery. What's happening is the screen uses too much battery before you can do anything, which usually means you need a new battery.
このアンサーは役に立ちましたか?
過去 24時間: 0
過去 7 日: 0
過去 30 日: 3
今までの合計 119
